olly
- Berthoud, Colorado
- Master Electrician
If you are running a feeder from the main to the breaker panel inside and you need to run it through a short piece of conduit to get down to the unfinished basement and then run over to the breaker panel, what is the best cable type. TC cable? Service entrance cable? What is allowed to be in a outside pvc conduit and then ran through an unfinished basement to get to the breaker panel. SER is not allowed to be installed outside in conduit correct? See picture.
Thanks!!
Thanks!!
