Jpflex
Electrician big leagues
- Victorville
- Electrician commercial and residential
If 120 volts is the limit between conductors supplying lighting systems for dwellings then if you obtain 126 rms volts or any voltage over 120 volts rms on your meter then this is a code violation?
What if utility has supply exceeding this by a small amount? Or transformer doesn’t have taps to step secondary voltage down further?
How do you redress this
