Jpflex
Electrician big leagues
- Victorville
- Electrician commercial and residential
Has anyone come across this type of electrical control for a hydraulic outriggers (construction vehicle)
Several toggle switches route 12 volts dc battery power to brushes sliding on slip rings to control direction of hydraulic fluid to control outriggers for heavy equipment tractor.
A single Voltage is spiced to surround each slip ring controller by toggle switch such as right rear outrigger out or in.
I assume ground is through vehicle chassis
I was wandering if this would be the field to turn a possible rotor but what about the necessary commutator for dc?
Has anyone ever come across a control system such as this? She picture
