how to hook up this UPS
electrofelon
Cherry Valley NY, Seattle, WA
I have a three pole 30A fused safety switch that feeds a 27KW 400V UPS. The output of the UPS then feeds three fused safety switches. I am not thrilled with the connection on the back of this thing. Recommendations? SO cord? Greenfield? What is that mini strut thing? Where can I get clamps for it?
Looks like 'C section' DIN rail
Looks like it is mounted to the enclosure using standoffs.
I'd probably change it to a similar sized rail I could buy from McMaster, and then use clamps for that.
Or perhaps replace the rail with a simple metal shelf with a couple of punched holes for Greenfield or cable clamps.
I presume there is a cover that goes over the terminals.
Jon
Not sure , but I can measure tomorrow. Probably about the width of your thumb. This needs to be up and running in a few days, guess I could zip tie the cord or raceway yo that channel for now.
If it is standard t track you can buy t track nuts at mcmaster or Amazon and bolt conduit hangers to it. Some t-track you can slide 1/4" bolts directly in the track and now you have a stud. Or slide a 1/4-20 nut and bolt a hanger to it.
Jon
Yeah I like the idea of a "shelf" to cap off the bottom and punch some ko's and terminate the raceways on.....but I didn't have time for that art project.
What I ended up doing is replacing that mini strut thing with unistrut and using strut clamps. Came out ok.
