jrjr2u
- Central NY
- retired
I have an old 3/4hp motor that has a starting issue. I removed the load and the motor spins freely. When I turn it on it sometimes won't start by itself. It will hum but given a little spin it will take off and run ok. I checked the cap and it seems to be in spec. It shows no signs of bulging or leaking. The cap is rated 150mfd and my meter shows it at 163. The start switch seems to be working as it should. Can the cap show in spec yet still cause this? Motor is made in Taiwan and dated 1977. It's a 120v motor.
