RatherBeFishin
- New York
- Electrical apprentice
Sounds silly but does anyone have a way they remember how to disconnect a car battery and reconnect the new one? Always have a brain fart in the moment and forget..
Very common in electronics. Not so much in vehicles.Disconnect the grounded battery terminal first, and reconnect it last.
This recommendation works on both positive- and negative-grounded systems.
Put a wrench on the grounded terminal, accidentally make contact with the car body and the other end of the wrench, nothing happens.
Do the same with the hot battery terminal and you'll have a red-hot wrench in your hand. A car battery can push a kiloAmp or two at room temperature.
12-0-12 split voltage system? Where has such a thing been implemented?
And a lot of sparks! It's a mistake that many people make, but most who do will not repeat. Yow!Put a wrench on the grounded terminal, accidentally make contact with the car body and the other end of the wrench, nothing happens.
