Jpflex
Electrician big leagues
- Victorville
- Electrician commercial and residential
I believe there is a code in NEC which does not allow “capped bend apparatus” to have splices such as cutting wires and connecting with wire nuts inside of this equipment such as LB’s or RB’s “elbows”
Is the picture posted a “capped” LB? would it be allowed here?
Also there is a code regarding equipment grounding conductors made of aluminum to not be installed within 18 inches of ground but would there be a similar code for EMT as I’m not sure if there would be any aluminum content in EMT?
