Alwayslearningelec
- NJ
- Estimator
I have a job with A LOT of ceiling fire alarm devices. THey are in a 2x2 acoustical ceiling. Would you always use a T Bar to mount the box?
What FA speaker is going to fit in an octagon box.Orbit FA box, looks pretty slick. None of past or present bosses would spend the money though. New stuff is scary, so t bars and octagons for us. The apprentice needs something to do anyway.
Oops. I first read it wrong. You sai FA device, I read speaker for some reason. Just use a caddy 512 with 4s box and mud ring.What FA speaker is going to fit in an octagon box.
No worries. Are you responsible for cutting ceiling tiles or does the ceiling guy on site do it? In the past I have typically had to cut tiles as needed, so an octagon box means I can just find center and hole saw. I’m imagining it being a pain to cut a rectangle for a mud ring into a tile, unless there’s some technique I don’t know about.Oops. I first read it wrong. You sai FA device, I read speaker for some reason. Just use a caddy 512 with 4s box and mud ring.
Some devices only fit in a rectangle. I can set a mudring down close enough to my center mark and run a pencil mark cut with drywall saw just as fast pretty much.No worries. Are you responsible for cutting ceiling tiles or does the ceiling guy on site do it? In the past I have typically had to cut tiles as needed, so an octagon box means I can just find center and hole saw. I’m imagining it being a pain to cut a rectangle for a mud ring into a tile, unless there’s some technique I don’t know about.
It depends on the device. Some like speaker stobes may go into a 1900 box with no ring. Others may require a single gang mud ring.do you alway need a mud/plaster ring for a ceiling fire alarm device? Thought the device goes in the box with a plaster ring for devices in a acoustical ceiling.
Thanks . Wall about device on gyp wall?It depends on the device. Some like speaker stobes may go into a 1900 box with no ring. Others may require a single gang mud ring.
Same applies.Thanks . Wall about device on gyp wall?
For some reason, our quotes all exclude cutting the ceiling tile, but our techs always do it when they are on site. They want to be in an out and don't have time to wait around for someone to mosey on over and cut some tiles when they feel like it.No worries. Are you responsible for cutting ceiling tiles or does the ceiling guy on site do it? In the past I have typically had to cut tiles as needed, so an octagon box means I can just find center and hole saw. I’m imagining it being a pain to cut a rectangle for a mud ring into a tile, unless there’s some technique I don’t know about.
