Alwayslearningelec
- NJ
- Estimator
Do you guys prefer steel or aluminum armor when installing branch size MC cable? I know the AL would be lighter.
That seems contradictory.If you're the guy pulling it aluminum is preferable for the weight but steel goes through metal studs much easier.
Well there is more than one type of pulling. Pulling within studs steel is better because it doesn't grab on the studs as easily, for pulling long homeruns aluminum is better because it's lighter. Given that it's easier to skin and lighter overall I would prefer aluminum.That seems contradictory.
Not sure if you are aware, but there is a correct direction for pull mc, especially through metal studs.I prefer steel. Yes, I know, heavier. However, I've never turned the armor into a Slinky when pulling. Stripping is just as easy in my opinion if using a good rotary cutter (maybe easier). I won't use the AL stuff anymore.
Mark
I was not; learning something new everyday. I guess I always figured you were stuck installing it in the direction it comes off the roll. But then again, I almost never come to metal studs. I would think with wood, the holes are symmetric.Not sure if you are aware, but there is a correct direction for pull mc, especially through metal studs.
No. Have 3 or 4 Roto strip brands that I prefer over at least 3 other companies that I used. We always cut all aluminum & steel jackets at a 45 degree angle and install at least one red anti short bushing no matter what the connector states. Have seen cable companies supply think it's 35 in a bag undersized bushings that do not cover the entire interior cable wall so that's when we install two anti short bushings 180 degrees apart. Wonder how many of the young sparkies ever came across the old paper fabric anti short bushings that would fall apart when cable was in damp locations. Think they stopped making them back in the 1960's.Does anyone make a rotary cutter that cuts at an angle to leave a less sharp knife point after stripping?
-Jon
