Rell
Super
- California
- Apprentice
Im doing submittals for a couple new data centers down south. What are some best practices gathering cut sheets to compile specs?
and we specifiers/engineerslike to seedemand submittals that are REVIEWED and APPROVED by the CONTRACTOR before we get them.
I just stamped mine REVIEWED. If the contract was giving me the authority to APPROVE submittals I would have stamped APPROVED.and we specifiers/engineerslike to seedemand submittals that are REVIEWED and APPROVED by the CONTRACTOR before we get them.
To answer your specific question, Google. I have tons of PDF catalogues saved in a folder on my computer. I assume you are asking about basic material, wiring devices, etc. Some people have a supplier do their submittals, but most of us don't want to ask a supplier, because that means we must either buy from them, or we are taking advantage of them. So I use a PDF program and just extract pages from a catalogue as needed. Then I put white blocks over parts that are on the page that aren't applicable. Like a page has steel set screw connector side by side with steel set screw insulated throat. I block out the column that I am not going to use. For individual part numbers in a column I use an arrow, or for a few rows, I use a box around them and an arrow to them. Lastly I flatten them, so my comments can't be deleted or moved. I always use blue and make a statement on the front that all electrical comments are in blue.Im doing submittals for a couple new data centers down south. What are some best practices gathering cut sheets to compile specs?
In the grand scheme of things, electricians and other specialty contractors are just peons in large projects.I just stamped mine REVIEWED. If the contract was giving me the authority to APPROVE submittals I would have stamped APPROVED.
Most times my submittals were products listed in the specs or equals that had gone through a substitution process.
You and I are in complete agreement which is the exact reason I only stamped "Reviewed"In the grand scheme of things, electricians and other specialty contractors are just peons in large projects.
Electricians, HVAC, Plumbers and other specialty contractors do not have the authority to approve submittals.. They are the ones who submit SUBMITTALS that are turned over to the GC
SUBMITTALS are an important feature in the services offered by consulting engineers and architects.
Sub-contractors are specialty contractors that support the GC.
They could recommend certain product and the kind of workmanship. . . . but nowhere in the document (specs) does it say that they have the authority in accepting or approving SUBMITTALS.
Those are jobs called Specialty Materials Custodian . . . . . not SUBMITTAL generators. Anyone can be a custodian.
Specialty contractors are just a COG in the wheel. Insignificant in a way thru the chain- of -command.
Chain of command is a proven and traditional way of structuring an organization authority level.
“It also ensures each employee is responsible for their own work but also has a more senior leader to offer support, encouragement and motivation.”
It’s an organization’s HIERARCHY.
This is a function of construction management that follows this chain strictly.
I used to work in a Consulting Firm as Assistant Specs Writer. My first desk job.
.From another poster:
During weekly meetings with the consultants on government jobs I would witness seeing my submittals sitting in a cardboard box someplace in the back of the office , unopened two years into the project. And after all that work putting the thing together and buying a rubber stamp to stamp each page of ten different books of the stuff , it kinda got me to thinking I ain't in the mood to ever sign another AIA contract ever again.
In many cases, SUBMITTALS are submitted and end up sitting idle in the copy room with nobody taking a look at it . (well, it seems)
When received, the front secretary would collate all submittals and marked that indicate FIFO (first in first out).
If your submittal needs attention , you just have to wait. In some cases SUBMITTALS take weeks and even months to get approved.
Chain of command is a very traditional way of structuring a company's authority levels.
It is common to see the same chain-of-command structure at various organizations.
