Krusscher
- Washington State
- Electrician
I am looking into retro fitting 23 2 lamp fixtures and have come across some concerns with doing this on previous post. They will be fed on both ends so shunted tombstones aren't an issue but what about the tombstones not being rated for being directly connected to a branch circuit instead of a ballast? Do I need to fuse each fixture to get around the tombstones not being rated for direct connection? Also does anyone have experience with inspectors giving them grief about not replacing the yellow wires going to the existing tomb stones that are now connected to the grounded conductor?
As a bonus question, I just replaced a CFL with a ballast bypass led and it came with a pretty large sticker saying it was modified. I put the sticker on the inside of the can trim but I feel like it takes away quite a bit of light as the inside of the trim is reflective but the sticker is not. Does the sticker need to go in the trim or can it be anywhere on the fixture?
