OldBroadcastTech
- Western IL
- Retired Broadcast Technician
What is the difference between what you recommend vs original?File is too large to attach but here is a link to it.
Page 4 shows order code.
Page 5 shows connector arrangement.
Page 9 shows the shell style you have.
Page 23 is the E/F style shell I'd recommend as replacement.
Mouser link to your exact plug
I'd recommend this as replacement
Thanks!
Yours is a 3106A… the “A” means it’s an open backshell designed to be overmolded.
The 3106E or 3106F has a screw clamp on the backshell to provide strain relief on your cable assembly.
So I wouldn't need an additional Kellum strain relief?Yours is a 3106A… the “A” means it’s an open backshell designed to be overmolded.
Tension strain is covered by connector thread and back shell, which is what a kellum would cover.So I wouldn't need an additional Kellum strain relief?
MS meets the military spec (heavy duty) and 97 is general duty.What is the difference between the MS and this 97 that old broadcast linked to?
Thanks, I appreciate you, and the others, who took the time to help. All info was great and helpful!!!MS meets the military spec (heavy duty) and 97 is general duty.
Just got the connector in. It came with no instructions. I can probably figure it out but thought you or someone might be able to guide me some.Tension strain is covered by connector thread and back shell, which is what a kellum would cover.
If there is more than 3-5 lbs in sheer (cable weight hanging perpendicular to connector) I'd find a way to support that.
Brush up those soldering skills! Yours is a large (8 awg) contact size so it shouldn't be too tedious to get into.
I also push the cable into the plug a bit as I tighten the clamp.leave the clamp completely off of the backshell, then install it after the connector is assembled.
I adjusted it when they tested the equipment. The clamp is also considered a strain relief. Also, they told me they don't handle the ring by the connector but had some previous workers that did.Looks good, your customer must be quite happy! Might want to adjust the the kellems grip so its tight on the cable and is taking most of the strain, looks a little loose.
