Hello, I have 3 30 hp motors 480 volt with a 60 to 100 foot distance to motor. (it is all in pvc underground in dedicated conduits run with a ground wire except going through the electrical room in emt, the motor disconnect and a gutter. In the electrical room they are now fed from buckets. I was planning to run conduit from mcc to the vfd location (about 20 feet of emt) on the wall then back to the bucket to splice in the vfd output to each motor. How many conduits are required? I am thinking best practice is to feed all 3 with one conduit but 3 separate pipes on output of vfds. (would save some pipe and labor if i can combine them for the 20 feet in emt in the electrical room)
