When dealing with stranded wire under a lug screw, what is best practice and what is permitted under NEC?
For example, simply use the stranded wire bare or add a ferrule to keep the strands together and less compressible, or solder the end to make it firm and bound and less compressible.
Several examples recently where the lug was torqued down, but many of the strands were not captured. Other instances where after torqueing and later removing, the wire was deformed and could not be reinserted, and had to be cut off. Which is okay, unless there no extra length.
