johnfluevogs
- NEW YORK STATE
- Engineer
I recently built a detached garage and am now deciding on how to bring service to the garage. NOTE: I am seeking opinions on different solutions proposed by different electrical contractors, and I am seeking to understand all the pros and cons.
The detached garage is 25 feet away from my existing attached garage where power will be taken from a main disconnect. The main disconnect is on the opposite side of the attached garage from where the underground conduit is placed between the two buildings. Therefore, the feeder will need to be run up and over the existing garage doors. In all from A to B the run is approximately 100' with at least five 90 degree bends.
Option A:
- install small single breaker box (100 A) tapped off the main disconnect
- run conduit the entire length (100 feet)
- install new 100 A sub-panel in new garage
Option B:
- replace 200 A main disconnect with a 200 A main load center (this would provide extra spaces/circuits in the existing structure for future)
Option C:
- Install new 100 A sub-panel #1 in the existing attached garage on the wall opposite from the main disconnect where the feeder will exist the building and enter the underground conduit (although a simple junction box would work, a sub-panel would provide additional circuit options for the future)
- Install new 100 A sub-panel #2 in the new detached garage fed from sub-panel #1 via the underground conduit
Thanks for reading and sharing!
***To be clear, I am not seeking advice or information about "how-to" wire/build the above.
If for some reason my request is in violation with the rules - then feel free to delete and feed me to the wolves!
Option A:
Option B:
Option C:
