Therealcrt
- Kansas City
- Electrician
I don’t do a lot of residential so quick question. Customer wants a new meter can installed with a new riser. Does the meter can need a ground from the grounding electrode (ground rod). Does the meter can need to be piped to the main breaker panel with rigid conduit or can it be pvc? Does the meter can even need a ground wire at all? I know the main breaker panel has the bare ground from the ground rods and neutral and ground is bonded there but what about the meter can itself..
