Given the following.
Micro inverter system
The bulk of the system is located on the house, however one array is located on a remote building on the property which feeds back to the combiner at the house.
Combiner and pv system disconnect are located at the front right of the house. Remote building is located at the left rear of the property. The circuit from the remote building will enter the rear of the home and then NM cable will be run to the combiner panel. Is a disconnect required where the circuit from the remote building enters the house? 225.31 seems to indicate that a disconnect is required.
