Been wanting to tackle something like this for a while. Customer had another PV contractor install the PV system and Inverter. it is my job to wire to the inverter-install a Generator inlet tied to inverter and panel, that will then wire a small shed. then from panel going to Home wire into the small home.
Completely off grid.
so his inverter is 1 SolArk 5 kW Inverter System
at 240 volt his system is 21amps. I am just back feeding With a 30 amp breaker to a , 200 amp main Breaker panel with feed through l lugs. and then going off that to wire shed, and wire home.
His inverter says he does not need a Transfer switch in off grid since the Generator goes to the inverter.
Seems straight forward.
His batteries are 2 Discovery 42-48-6650 AES 130 Ah Lithium Iron Phosphate Batteries
I don't know were they are located I am hoping in a separate room. Never been to site just quoted over phone. I may break even for how little I charged him. It just seems a good being step to actually put my hands on a system. Never have seen one yet.
Any advice would surly help and I know its kinda vague. I am just worried about connecting to the panel. but seems straight ward.
Since this is something I have never done I have to physically touch it and read the code book at same time. only way I learn.
