Alwayslearningelec
- NJ
- Estimator
Dumb question. Is the only difference between the two is that one is 1 pole and the other is 2 pole? Thanks.
The 125 volt is rated for a maximum voltage of 125 volts. One ungrounded conductor, one grounded conductor, and one equipment grounding conductor. The 250 volt is rated for a maximum voltage of 250 volts. Two ungrounded conductors and one equipment grounding conductor. The old two wire receptacles don’t have a equipment grounding conductor. Google NEMA configuration chart!
No, grounded contacts are poles just like ungrounded ones are.Dumb question. Is the only difference between the two is that one is 1 pole and the other is 2 pole? Thanks.
Well Augie says (2) ungrounded conductors isn't that 2 poles?No, grounded contacts are poles just like ungrounded ones are.
The difference is slot shape, which is basically a rejection feature.
And, no, it's not a dumb question.
