Contactless27
- USA
- Electrical Engineer
Hi All,
I'm looking to install a 24kW Generac at a residence with 400A service and would like some advice. There is a meter main combo with two 200A service disconnect breakers. From there, 2 sets of SER cable runs to 2 panels inside the residence. The inside panels are all the way on the other side of the residence - probably 40' away. I'd like to disconnect the existing SER wiring from the 200A breakers and route them into a new junction box sitting right below the meter main combo, splice them to new wire in the junction box, and run it to 2 Generac 200A ATS boxes via separate conduit to each ATS. The utility feeds from the breakers would be new wiring and would run to the ATS via separate conduit to each ATS.
1) Are there any code issues with this, particularly the part about using the existing SER wiring/nipple inside the meter main to feed the inside panels from the ATS via the junction box?
2) ATS #2 in the image will be just over 3 feet from the vent on the NG regulator. Is this an issue? By 3' I mean radially / line of sight, not horizontally. It would be less than 3' horizontally.
3) The conduit (PVC) running from ATS 2 to the gen will be attached to the wall and run right behind the NG meter. Any issue with that or clearance requirements there to worry about?
I'm attaching a diagram (link below) to better illustrate... Thanks for any comments!
Diagram
Diagram
