My state agrees. Not required in WA
Yes, no where near the same area, and not even a permitted grounding electrode per the NEC, but was common for a long time. Typically there would only be 5 or 6' of the 6AWG around the bottom of the pole.And here we have what's common running into what's code.
BTW, the surface area of a 5/8" x 8' rod is about 181 sq in, you'd need almost 30' of 6g to match that (yes, I do have better things to be doing).
If it was the top half of a rod then might be harder to prove it was not proper, I could never bring myself to pull a stunt like that.I may know a guy that has half of an 8' rod that he might use for a rod on a temp service. He thinks it's easier to remove when the temp is removed. I think I heard him say it was just a "joke rod" anyway!
I'll let him know!If it was the top half of a rod then might be harder to prove it was not proper, I could never bring myself to pull a stunt like that.
