Alwayslearningelec
- NJ
- Estimator
If you had a single phase motor would a 3 phase disconnect ever be used for the OCPD or it would have to be 2 pole disconnect?
For 120 volts you would use 1 pole. Although you could splice the neutral I would use a disconnect with a neutral kit in it.Ok, so you would only use 2 of the poles on the disco for 208v? What about 120v?
I sometime get confused when it comes to voltages, phases and number of wires used in the specific voltage/phase application.
So obviously you can have single phase 208v???For 120 volts you would use 1 pole. Although you could splice the neutral I would use a disconnect with a neutral kit in it.
Sure, any two phases off a 208 3 phase system would be 208 single phase.So obviously you can have single phase 208v???
Yes, and we have had plenty of discussions about it, including recently.So obviously you can have single phase 208v???
That would be an installation where you are permitted to switch the neutral.For 120 volts you would use 1 pole. Although you could splice the neutral I would use a disconnect with a neutral kit in it.
404.2(B) Grounded Conductors.
Switches or circuit breakers shall not disconnect the grounded conductor of a circuit.
Exception:
A switch or circuit breaker shall be permitted to disconnect a grounded circuit conductor where all circuit conductors are disconnected simultaneously, or where the device is arranged so that the grounded conductor cannot be disconnected until all the ungrounded conductors of the circuit have been disconnected.
I'm so sorry. See you said any two phases? That's what confusing. Two phase conductors but single phase. I understand it's correct but just hard for me to wrap my head around when I hear (SINGLE) phase but TWO phase conductors. Again I understand it's 1P/208v.Sure, any two phases off a 208 3 phase system would be 208 single phase.
Thanks. But I don't think you would ever have a disconnect switch(handle/knife type) that would only have one phase connected to it, correct?It is a confusing term.
There is a two phase system but they are rare and would possibly confuse this situation.
As stated, you could have a disconnect with one phase. Best example being a light switch on a 120v circut
Single pole versions of that are available. Typically one knife blade switch and a terminal block to splice the other conductor of the circuit.Thanks. But I don't think you would ever have a disconnect switch(handle/knife type) that would only have one phase connected to it, correct?
Sure you could have a 120v or 277v line to neutral load that needs a disconnecting means. Due to availability, I would likely use a two pole switch with the other pole not used. Actually the situation where I have needed just one pole, just a few months ago in fact, is on a 240/415 system. I needed to take some line to neutral taps off this system. I could have used a 480v panel board and breakers, but I didn't have time to order that equipment. The disconnects I could get immediately.Thanks. But I don't think you would ever have a disconnect switch(handle/knife type) that would only have one phase connected to it, correct?
Try to see it for what it actually is, and not worry about what it's called.I'm so sorry. See you said any two phases? That's what confusing. Two phase conductors but single phase. I understand it's correct but just hard for me to wrap my head around when I hear (SINGLE) phase but TWO phase conductors. Again I understand it's 1P/208v.
As I said above, you treat 120/208 1ph just like 120/240v 1ph.So whenever you have single phase you would never have 3 phase conductors obviously but either one or two phase conductors? But when using a disconnect you would never have only one phase conductor?
No, you can always use a higher-rated switch. Voltage rating is a minimum limit.Finally, if you had 208v circuit would there be any issue using a 600v switch or it would have to be 250v?
To add, the term "phase" is being used here to refer to "line" when you hear that. Some even use phase when referring to the two lines of a 120/240v 1ph supply, which we know is single phase.I'm so sorry. See you said any two phases? That's what confusing. Two phase conductors but single phase.
Just with the exception that 250 volt and 600 volt fuses are typically physically different so with a 600 volt switch you would need 600 volt fuses even if your system was 250 volt.600V switches, fuses, and breakers are all compatible with 240V, 208V and anything less than that, by design. As long as it's still AC.
When I was a kid, these were everywhere, Service to small out buildings, Pump houses for shallow wellsThanks. But I don't think you would ever have a disconnect switch(handle/knife type) that would only have one phase connected to it, correct?
, disconnects for small machine tools
