can you change the speed of a motor?
zappy
CA.
We have a 1/2 HP 120/240V motor for a exhaust fan on the roof. There saying the CFM should be more on there tester. Right now we have the 120V wired on the Low Voltage side of the motor. Anything we can do to change the speed to get more CFM? thank you for your help.
Increasing the speed of the fan blades will result in an crease in current drawn. How loaded is the motor?
Or is there some other problem - restricted duct work from being too long, to many angles, too small a diameter, obstruction, clogged filter, ... Obstructions that reduce air flow should reduce load on the motor, so that would be one clue that ducting is a problem. More air flow needs more power.
If the motor current is near its rated current, then the fan is probably moving all the air it can. If you need more flow, you need a larger fan with a larger motor.
Exactly!
If current were low, it could be a duct restriction, and changing fan speed would not necessarily help and would draw more power.
Only if the motor is underloaded would I suggest a ratio change.
Is there a design document for the system that leads them to expect more airflow, or are they just saying that the downstream operation needs more air?
Note that a serious obstruction, that cut the airflow, but, say, a factor of 3, would also dramatically reduce the power drawn by the motor.
Positive displacement pumps are a whole different story.
If you are a tin knocker then have at it. Especially if you keep air flow testers in your truck.. Im not sure what your comment means... But i understand the implication.
Being able to tell the customer what is wrong and how it needs to be addressed is a plus. Even if you need to pass on the project yourself.
I got a lot of electrical calls that were anything but. Most of us do.
One of my help fixed an elderly customers oven door because he noticed she had to hold it shut with a chair. That got us more points than what he was there for.
To the OP's original question, most (all?) single speed AC motors' spin rate is determined by the frequency of the AC power supply, so unless you can change that you cannot change the speed of the motor.
Aside: Many years ago a friend of mine ran a small recording studio, and he wanted to vary the tape speed through his TEAC four track machine. He got a large solid state bass amplifier and an oscillator, and he wired the AC input of the tape machine to the speaker output of the amp. He turned up the volume on the amp until the voltage was 120V; he monitored the frequency of the oscillator with a Conn Strobotuner and the AC voltage on the speaker output with a DVM.
It worked.
