If you’re using emt as your ground then could you not just use a bonding pigtail, And all grounds are made up?Rules here say for the rough inspection, all boxes made up, grounds connected, etc. Be hard to not run wire if grounds are to be made up.
That is with or without conduit. We can cover walls before rough if using conduit, but not cable methods.
