Joethemechanic
- Hazleton Pa
- Electro-Mechanical Technician. Industrial machinery
You are misreading the or taking the OP too literally. 24V is not the source voltage. Nobody drowns because they fall into the water holding a battery, but it only takes a voltage gradient of around 10V from a faulty wire or stray voltage around a fresh water dock or swimming pool to paralyze someone and they curl up and sink in the water and don't come up.
I was just going by this statement.
In HVAC school I was taught that 24VAC was "safe"; it was low voltage.
And yes in that context 24 volts is safe. Unless you are talking about fires, and I've seen that happen with just a few volts
