I'm a little bit confused on where to apply the 83 percent rule. In the 2020 code book, 310.12 (B) talks about applying the 83 percent rule to feeders in dwelling units. Does this mean, that if I am adding a 100 amp sub panel to a 200 amp service main panel, that I can run #4 THHN (which is 85 amps in the 75 degree column) and put it on a 100 amp breaker?
