EEngineer007
- TN, USA
- Engineer
Hello,
I have a 15kV incoming cable at a distribution transformer, and we are running underground concrete encased duct bank.
Do we require space below the distribution transformer in the range of 10' high?
Also, I also want to know what happens to number of cables once they transition from Underground to Open air. For e.g. if there are 6 cables in the underground duct bank, and then it comes in the building (open air) and further goes to another substation which is 1500ft away.
Do we have to carry 6 Cables to the substation which is equivalent to the ampacity of the cable when underground, or shall we reduce the number of cables based on open air ampacity? Probably to reduce the number of cables a transition box will be required.
