ItsFrank
 - California
 - Electrician
Alright so I have 3 receptacles on 3 different circuits all are GFI’s. When using my plug tester I get an open ground to all of them, I went back and tightened all connected points for the ground all the way back to the sub and main panel. Everything tones out, even through the GFI’s if I wire nut the neut and ground together but, I still get a open ground reading on the tester. (It’s a outside quad area, in Irvine CA. In case folks know local codes) any suggestions for troubleshooting is appreciated.
