electrofelon
- Cherry Valley NY, Seattle, WA
- Electrician
Just finishing up 4 townhomes. Originally it was my understanding that the hoods would be hard wired, so I had in my mind to provide AFCI only protection. At the last minute, I am informed the hoods are the microwave hoods that plug into a receptacle in the upper cabinet. I cut in a box and install a receptacle. but space out that they would require GFCI protection if within 6 feet from the sink. Inspector comes for final, notices it and says the require GFCI, writes it up as a correction for all 4 units. Ok yeah, my bad I totally spaced on that, they seem pretty close to the sink. So I go to put them in and get out the tape measure and find that two of them are under 6 feet, and two are 6' 2". I go ahead and install a GFCI recep in the two that were under 6 feet. Today was re-inspection. ITs a different inspector, and I wasnt there but my guy was there. My guy shows him with his tape measure, 6' 2". Inspector says a bunch of nonsense like all receptacles in a kitchen "should" be GFCI protected and says multiple times, "why didnt you just do it??" What is this Nazi Germany? I was super busy today but I will be calling the district supervisor tomorrow. I am not letting this go, I am super annoyed at the Gestapo attitude and the "come up with you own numbers in the field" philosophy. I know this seems minor, but the Seattle electrical code is crystal clear on this. There is no debate whatsoever. Ill let y'all know how it goes tomorrow.
