I have a friend whom has a large property and 8 of his valves were not functioning ; all in the same line  , about 300 feet from control source . The 8 out were all in line and at the end of feed . My first inclination was damaged wires underground  . I isolated wires from valve on first of 8 closest to source and had no apparent short , brought power to that valve isolated from valve and had 26 volts . Once I connected the valve voltage went down to 3 volts . I swapped a working valve and the same thing happened ?? I`m lost next step relocate power supply with new wire  . any insight .
