Our utility just provided service to a new construction, and has connected to a pole on our property - I believe the connections are to 21 kv line. The transformer is a pad mount sitting on the property of the new construction. The hot line has a fault tamer cutout, and for some reason they connected the primary neutral via a solid blade cutout. The use of the solid blade cutout requires clearing 10' radius around the pole, which is what prompted my post.
The utility's engineering says that the neutral is required to be fused, not just the primary hot.
This doesn't make sense to me - I can't think of any benefit in fusing the neutral, and can think of undesirables.
Is there a code requirement that specifies fusing the neutral? What fault situations would fusing the neutral handle that the primary hot fuse wouldn't.
