For a customer owned outdoor sub (~80MVA) where there's HV transmission coming in, and then the secondary voltage is 34.5kV and several (3?) 34.5kV feeders are going to run underground from the sub, would it make more sense to have a metal enclosed switchgear lineup that had these MV feeder breakers, so the underground feeders stubbed up into the switchgear, or would it make more sense to do more of the classical outdoor substation breakers with open air bushings on top and built on a custom structure.
I would think outdoor substation breakers make sense if you're going from overhead, and then staying overhead, but if you're transitioning to underground, it would seem like a switchgear lineup would be better. Perhaps there are outdoor sub breakers specifically made for transitioning to underground though...
We're just doing some early stage prelim designs and I want to see if there's a direction that is abundantly better than the other.
I'll take any insight I can get from the crew here.
