JimInPB
- South Florida
- Engineer
I've recently been working on some small solar systems in the 25W - 2Kw range. They feed 12vdc battery banks on boats. I've used 3 types of hard panels & 2 types of flexible panels. Ratings, performance and durability have varied quite a bit. I'll post what I've seen. I'm hoping that others will chime in with their experiences so that I will be able to get a better feel for what is out there.
The best brand of hard panels I have worked with have put out slightly more wattage than they were rated for. It was enough overage that I had to resize some wires & breakers. These were kind of heavy, but they work well. The 130W & 250ish watt panels both performed beyond their ratings and are holding up well in a marine environment.
The poorest hard panels that I worked with put out 40% less than they were rated for and are less physically durable. (harbor freight junk)
The best performing soft panels that I have worked with put out about 95% of rated wattage, but they get very hot, the backing dents easily, and they seem fragile.
The other flexible panels I worked with put out a little less than 60% of rated wattage, but weigh little, don't get so hot, & seem physically durable. Identical looking panels are sold under a different brand name with a lower rating. If they are the same panel, as I suspect, then the output would be 25% less than that wattage rating.
Some 10 year old hard panels, of a very good name brand, seem to be putting out about 75% of rated power, after all those years. The other panels I spoke of were all new, or nearly new.
