junkhound
- Renton, WA
- EE, power electronics specialty
imo filing is not abrasive or chemical....? Sandpaper leaves grit so would be a no. How about wire brush, stainless of course only.
IMO, if they look bad, replace them. Removing the silver from the contacts certainly will not help.
You however could pry up the wire terminal at the solder joint on the commutator to get more life out of the worn out carbon block, from motorcycles to power tools...From working with my uncles doing automotive electric I remember they told me never to use emery cloth on commutators or ignition points. The reason was that the emery abrasive would embed in the surface and cause arcing. We always cut commutators on the lathe, and properly undercut the mica. Ignition points were filed.
And don't forget to test the armatures with the growler![]()
Lots of starters would get overheated and throw the solder out of the "hairpins". Some were worth resoldering, some it was cheaper to replace the whole armature, if you took into account the time involvedsolder joint
Yeah that was my understanding at the time also. Now there are so many different abrasives that I'm unsure. We used to do work for a copper smelter. There was a company that made abrasives out of thne slag from the smelting process. I know for a fact that that slag was conductive, Dust from the stuff caused all kinds of problems with anything electrical. It used to build up on the top of the batteries of the equipment that worked on the slag piles and discharge them overnight.as I understand other sandpapers are not.
In particular, if the contact surfaces have pits and ridges from arcing, there is often totally insufficient contact area to carry the load current. Smoothing the contact surface, even if the coating is removed, will buy you some (short) time.Absolutely, but sometimes, dressing up the contacts can buy you some time to procure a replacement.
