winnie
- Springfield, MA, USA
- Electric motor research
if you are on the 2020 or 2023 code cycle, you will need an outside emergency disconnect at the house.
Code requires an emergency disconnect outside of the house. I'm guessing it is an AHJ interpretation if a disconnect breaker at the meter 150' away from the house counts. It is clearly a disconnect, and it is clearly outside the house.
Copper because it is top shelf! Why do I only use metallic wiring methods in my own home?
-Jon
