1600 amp service switch with 1600 amp fuses feeds a switchboard. I 10 ft tap ahead of this switchboard and install a standalone 800 amp switch with 750 amp fuses to feed a load.
I know that on the load side of 800 amp switch the equipment grounding conductor needs to be 1/0.
But should the equipment grounding conductor between the switchboard and 800 amp switch be 1/0 or 4/0? (all conductors are copper)
