- Tennessee NEC:2017
- Semi-Retired Electrician
I was just checking my portable generator (7.5KW) and was looking in the manual. I came to this part and wonder why they keep insisting the generator be grounded to earth via a ground rod? They even go so far as saying it will protect against an electrical shock.
4.3 - GROUNDING THE GENERATOR
The national Electrical Code requires that the frame
and external electrically conductive part of this genera-
tor be properly connected to an approved earth ground.
Local electrical codes may also require proper ground-
ing of the unit. For that purpose, connecting a No. 10
AWG (American Wire Gauge) stranded copper wire to
the grounding lug and to an earth-driven copper or
brass grounding rod (electrode) provides adequate pro-
tection against electrical shock. However, local codes
may vary widely. Consult with a local electrician for
grounding requirement in the area.
Proper grounding of the generator will help prevent
electrical shock in the event of ground fault condition in
the generator or in connected electrical devices. Proper
grounding also helps dissipate static electricity, which
often builds up in ungrounded devices
