I use a Greenlee 501 Tracker II that works pretty well, but unfortunately it only works on dead lines. I’ve been able to locate paths and faults within a foot, and guesstimate the depth within a foot. ...You may be able to use the Tracker II on the neutral, but due to multiple bonds, if there is any rebar or other grounded circuits in the area, you may get false readings.
Yeah, probably CT something or another. Some one recently posted a picture of it. It has a jack for an earpiece, but it’s still hard to hear the low signal power.I have an amp probe but I have never had good luck with it under ground. I don’t remember what model it is but it’s a little handle held receiver and a battery powered or line powered transmitter
I have that clamp, but never used it. Don’t know how well it works. But for the money, it’s a decent tracer.Looking online it appears that the Greenlee 501 Tracker II includes an inductive clamp that can be used to couple the transmitter output to the conductors. The documentation said:
"The transmitter is protected against damage from inadvertent direct connection to voltages up to 250 VAC. However, direct connection to energized cable is not recommended. The inductive coupler Model IC-1 is included for such
applications."
About the same at the supply houses and Amazon.The 501 look to be about 400-800 on eBay that’s not bad at all
I have one it's only ok for underground it does fairly well inside walls though.I understand the new Klein ET 450 will trace underground. It works on energized or dead wiresl
What is the average price?You can hire a private locater service, or rent one from a contractor rental company like Sunbelt, United Rentals or others. Buying one is pretty pricey.
