dm9289
Industrial Maintenance Electrician
- Pennsylvania
- Industrial process repair/ maintenance Electrician
I do know that its not good practice to share holes with other trades. But i do not know a code ref prohibiting (except other insulation ratings). I see many locations with a hole from the garage to the basement the plumbing is generally PVC drainpipe, the holes are usually a bit oversized due to block blow out. NM cable is generally just stuffed alongside can I get help with a code ref prohibiting this?
