JJWalecka
- New England
Is it legal to just install a new light on old K&T. can't seem to get the owner to budge on removal and rewire....they just want an old light installed...
That if the circuit is gfied then you can replace stuff on non grounded circuits.I apologize I don't have my code book on me...what does 410.44 exception 3 state?
Thank you
Yes, on existingThat if the circuit is gfied then you can replace stuff on non grounded circuits.
Only ones I've seen that meet this are driver pendants, integrated led outdoor lights, and some nicer disk lights.Look at exception #1 also. If you can find a fixture with no exposed conductive parts, then you won't need GFCI.
Some ask for 75 or 90 insulation but there's work around with this tooSomething about manufacturers instructions and temp rating of wire? I don't remember
Porcelain Keyless fixture?Only ones I've seen that meet this are driver pendants, integrated led outdoor lights, and some nicer disk lights.
Exposed 832 screwsIs there a box on termination end of K&T designed for K&T? if not good luck finding insulators. Seen many that are just flying splice or improperly put into a MC box with no insulators.
For holding a ceiling fixture I think you'd need something rated for the 50lbs. For a wall keyless I think that'd flyHa-Ha!: Nylon screws!
