prattz99
- Long Island NY
- Electrician
Hi all,
I'm back at it again with another weird one. I was removing a down light similar to a Halo SDM6 surface mount down light (I'm sorry I don't know the exact fixture at this point) when I did so I got a small tingle when I touched the metal soffit. I took a voltage reading and found it was 50 volt AC when the dimmer switch was on. Fast forward to today when I go to replace the fixture and I measured 30-32 volts from a clip on the housing of the SDM6 to ground. My question is: Is this acceptable to install? I thought it might be a defective fixture so I tested another Halo SDM6 fixture and it measured the same voltage. If it's less than 50 I think it's okay but I'm curious what you all think. Also, would it "level off" if the fixture was connected to ground?
