lew5679
- Leominster, MA 01453, USA
- maintenance manager
I have heat circuit 460 volt with 5 heaters. the heaters are 2 wire. so one leg is connected to one side of 3 heaters the other leg is connected to one side of the other 2 heaters and the last leg is connected to the other side of all 5 heaters. each leg has a different amp fuse 25A 20A and 30A . I would like to switch this circuit over to a breaker instead of fuses. should i put in 3 different size breakers or would a 30A 3 pole breaker work. the wire size is all the same on the entire circuit.
