Smash
 - Philadelphia suburbs, PA USA
Can anyone recommend a single phase 240V cycle timer for a 1/4 HP motor. This is for a small chip conveyor that will be attached to a large steel cutting saw. The conveyor will simply carry the chips away from the saw into a bin. Need something for an oily industrial setting. The operator will simply turn it on and the timer will cycle for a man shift on approx 10 min then off for 30min and repeat. Or be custom programmed for that particular day of cuts. I could install  an emergency stop button next to or if it came with one perfect. No variable speed no reverse just on off at programmed times. 240V Thank you for suggestions.
