I believe I know the answer, but I would like another opinion. on a 120/208 circuit breaker panel, I have a single breaker with 2 breakers on it.
If I install two wires from the same service to the twin breaker, does the neutral see the entire load of both wires,? Instead of the imbalance
of the 2 lines? If I am drawing 10 amps on one leg and 5 amps on the other, would it be 15 amps on the neutral or 5 amps on the neutral?
Thank you for the feed back..
