Electromatic
- Virginia
- Master Electrician
A customer has a table saw that suddenly won't run. When you press start, the main (K1M) and star contactors (K3M) pull in, but the motor doesn't turn. When the timing relay switches to delta, the delta contactor (K2M) tries to pull in, but then the whole thing shuts down. I had to replace the main contactor about a year ago, so I was suspecting the delta contactor failing, but with the motor not turning in star, I have second thoughts. One other important thing is that this is at a residence and is using a rotary phase converter to get 3-phase.
Thoughts on things to check or try?
