Tip DS
I'm here.
- The Great Meme State
- Electrical Engineer
Scenario: 240/480V 3-Phase Y-wound electric motor has a damaged 3-6 coil. Can the motor be re-connected from its 480V configuration to the 240V configuration (bypassing the 3-6 winding [and the 1-4 & 2-5 windings]) and be salvaged for temporary use at 240V?
I realize the motor will have to run a higher current at the lower voltage. Assuming the voltage and current can be supplied, is this a workable solution to keep the motor on-line while a replacement is obtained?
