anees ur rahman
- pakistan
- student and solar designer
I would say yes it's ok, but you will want to evaluate the power loss. It's basically the same thing as having a DC to AC power ratio greater than 1 which is fine to some degree.Hello sir
can i use inverter that DC maximum input current, per DC input is 12A with moduels that has
Imp (STC):
Isc (STC): 13.11 A
14A
i also attach datasheet
@electrofelon this can not hurt inverter?I would say yes it's ok, but you will want to evaluate the power loss. It's basically the same thing as having a DC to AC power ratio greater than 1 which is fine to some degree.
Since the inverters maximum short circuit current is 30 amps, I would say it is fine. The inverter will not self-destruct itself.@electrofelon this can not hurt inverter?
@electrofelon thank you so much sirSince the inverters maximum short circuit current is 30 amps, I would say it is fine. The inverter will not self-destruct itself.
