Rdel6937
- New Jersey
- Electrician
Afternoon all,
I have a customer looking to upgrade his 200A service to either 300A or 400A in Fairlawn NJ.
He is at approx. 80% utilization on his existing service and would like to add a second 200A panel as he will be adding 2 EV charging stations and wants room for growth.
PSEG already inspected the tri plex and it is good for 300A. a 400A upgrade would need to be reviewed and I believe there is a 300A meter pan, just not sure if it comes with a disconnect means.
Questions:
Is there a 300A or 400A Meter Pan with Disconnect means and dual load lugs where I can attach the existing 200A panel load and then run a new 100A or 200A service to a new panel in the garage? (eliminating the need for a trough and bugging in each panel.
What are the grounding and bonding requirements for this setup or if using a trough and bugging in the panels.
Any other ideas or thoughts how to deliver the additional capacity? there is no room for an additional panel near the meter pan and service entrance. It will need to extend the additional service and panel to the garage.
Questions:
