Or heat.I wouldn't want to regularly expose the panel to that much humidity.
The temp inside a dry sauna according to google can be 200 degrees F. That is just not a suitable location for your typical electrical equipment. If I were the inspector I would ask for documentation from the manufacturer that it's safe to install in such an ambient temp or else fail it citing 110.3(A)(1) and (5).
Doesn't a dry sauna have a pile of hot rocks and you dash a scoop of water over the rocks every now and then? Not as dry as you think!
