3 phase Voltage
td1236
California
3 phase voltage is 240 between all phases, A phase to ground is 120, B phase to ground is 208 C phase to ground 120.
Why would B phase to ground be 208?
As Tom stated it's a 3 phase, 4-wire Delta system. One of the coils has a center tap to provide the 120 volts but has a higher voltage to neutral typically from the B phase.
Three Phase Transformer: What Is It? How Does It Work?
What everyone else said plus it should have been identified by being 🍊 orange.
Which, by the original definition makes it not a true "neutral" conductor (same voltage to all ungrounded conductors), but the Code decided to call it one anyway in this context.
Considering that the high-leg open delta started as a modification to existing 1ph services, I think it still fits.
I can't think of a better term for it, especially to the A_C winding. It's definitely still the grounded conductor.
I can't think of a better term for it. It's definitely still the grounded conductor.
Whereas, I would say that the white wire started out as a neutral, but stopped being one when the third phase conductor was added. :)
I would just call it the grounded conductor. Among other things, I think the white wire needs to be counted as a CCC in a full boat if the high leg is used for single phase loads.
I like the "new" version where we call it a neutral. It's a white conductor that most call a neutral anyway. I never really saw the need to have a distinction between a neutral and a grounded conductor with a 4-wire Delta system.
Trigonometry.
Just like was discussed in this thread: https://forums.mikeholt.com/threads/three-phase-ampacity-calculations.2577416/
Refer to the image in post #4 of this thread for the visual representation.
You have a 30-60-90 triangle, know the short leg (120V) and the hypotenuse (240V), and are looking for the long leg.
cos(30)=x/240V
Sqrt(3)/2=x/240V
x=120V*Sqrt(3)
x=208V
… but has no real connection we can utilize
And yet, this question (using the 208V for something) arises here (and elsewhere) surprisingly often. I think if it kind of like having a button on the wall with a sign that says “DON’T PUSH THIS BUTTON!”, there will always be someone who has to push it.
What I was getting at was the true neutral of the delta itself is a point in the center of the delta that has no possible way to connect to without some sort of wye connected circuit between the three corners of the delta.
